I’m planning a loft in my daughter’s bedroom,using a 12.5 foot beam, 10″ x 4″, with two posts positioned so the longest span is 6 feet. My question is: How does one go about RAISING the beam up onto the posts? This sucker is heavy!
Several methods come to mind, but need to know if you have clear space above it (genie hoist or rig up an A-frame and come-along). No space above, get it up on some scaffolding and jack it into place, or get a helper.
Address a posting to Frenchy.
Or, get the Taunton book, Working Alone.
I've put up much bigger wood than that alone...where there's a will, there's a way!
Be careful though and always consider worst case failures of your rigging.
I've raised some hellacious beams alone using a pair of wall jacks. I'll try to resize a photo to post of my son jacking one into place. I put a 5+1/8x18x23' glulam in alone in the same house a couple years ago. Piece of cake. Hardest part was cutting a hole in the wall so the lumber truck could tip it onto my 3" ABS pipe rollers so I could get it where I wanted it before I installed it.
okay, this could take a couple trys, been a while since I used infranview...
we used a lift called a Duct Jack it is used in a lot of commerical construction, We rented it at our local tool rental. $30.00/week. The beams we raised were 3-1/2" x 14" x 20' LSL. It works very well.
Tim
Prepare a notch seat for one end and lift one end up and in. Then same at other end. you are only lifting one end at a time that way. This barely qualifies as heavy, though I wouldn't want it dropping on my toes. My floor joists are 4x10 x 14'. I set them as green timbers this way, one end at a time.
i raised a120kg 8*4 with 1/2" steel fitch plate 8' a couple of months ago.
used a car trolley jack in the middle and a helper at one end to keep it steady.
you jack it up , prop it up, raise the jack and start again.
much easier than all that humping it around.
aleks
