Random Orbit Sander “Q”
JDRHI | Posted in Tools for Home Building on September 23, 2008 07:47am
I have a Bosch 5″ ROS that is several years old, but has not seen a ton of use.
Last week on the job I turned it on and the head (pad) went flying off.
The hex head screw that holds it on had come loose.
I attempted to put it back on, but the screw wouldn’t tighten…appears to be stripped. (Not the screw)
Anyone ever had a similar problem?
Is there an inexpensive remedy?
Were it the screw itself, I’d replace it.
Ideas, short of bringing it in for repairs?
J. D. Reynolds
Home Improvements
    Luka | Sep 23, 2008 07:52pm | #1
    Helicoil.
    If there is enough metal there.
    What a fool believes he sees
    No wise man has the power, to reason away
    Click here for access to the Woodshed Tavern
    Click here to have access to the woodshed tavern revoked.
      JDRHI | Sep 23, 2008 07:55pm | #3
      Should my local hardware store carry em?
      Bring in the screw for sizing?
      J. D. Reynolds
      Home Improvements
        Luka | Sep 23, 2008 07:58pm | #5
        Yes and yes, Auto parts stores have them, as well.
    Luka | Sep 23, 2008 07:54pm | #2
    You have to drill out, and re-tap, for a helicoil.
    If there isn't enough metal there, for that, you might try just retapping just slightly larger, and using a slightly larger screw.
      JDRHI | Sep 23, 2008 07:56pm | #4
      If I screw that up, am I out a sander?
      J. D. Reynolds
      Home Improvements
        Luka | Sep 23, 2008 08:00pm | #6
        No more so than you are right now.If it gets screwed up, try finding the part number for just the part of the sander, that the screw goes into, then search online for the part.
  3. dovetail97128 | Sep 23, 2008 08:12pm | #7
    It may be possible to LocTite or Epoxy the screw into place.
    IF there is enough left of the internal threads to get a grab of the hex screw threads.
    Repair may last a long time, may not but I sure would give it a try.
    Best answer I have short of sending it off for repairs.
    observer | Sep 23, 2008 09:50pm | #8
    Had a Bosch that suffered a similar problem.
    Solution was a Makita. That one suffers from premature wearout of the disc binding hooks on the expensive backing pad.
    Solution to that was a Metabo. So far, so good.
  5. FastEddie | Sep 23, 2008 09:54pm | #9
    Try the next larger screw size.
    Put some steel wool scraps in the hole and a drop or two of epoxy, insert the original screw while the epoxy is wet.
  6. dovetail97128 | Sep 23, 2008 10:31pm | #10
    I just remembered that there is an epoxy product (2 part, well actually 3 part) out there that you coat the screw with an anti-seize material and fill the internal threads with the 2 part epoxy part of the kit.
    After coating both pieces with the appropriate material then you let it set up and unscrew the screw or bolt , wipe clean the anti-seize compound and re-fasten the parts.
    Don't know where it is available but know it exists.
    Be guessing an auto parts store.
  7. saulgood | Sep 23, 2008 11:51pm | #11
    . I've never tried the helicoil solution, but I will say that the 2 part epoxy method will buy you some time if done well. I'm on my second Bosch ROS right now. The first one, a five inch, broke like yours so I did an epoxy repair which lasted until the tool was stolen. Then I bought a six inch bosch which worked great until the screw broke OFF. I removed the stub with an "easy out" and replaced it with a hardened allen screw which should last longer. I used Loctite red on the threads and have had no problems since.
    The main thing is to keep that screw tight at all times. If you own one of these sanders -or any random orbital, for that matter-I recommend applying a threadlocker to the center screw right out of the box, before problems arise.
  8. cynwyd | Sep 24, 2008 12:48am | #12
    can you tap it to the next larger size?
    1. Talisker2 | Sep 24, 2008 02:18am | #13
      You could just buy a Festool sander and be done with it. <G> It does cost a "little" more tho.
      Edited 9/23/2008 7:19 pm ET by Talisker2
  9. User avater
    Sphere | Sep 24, 2008 02:39am | #14
    JB Weld in the hole, vaseline on the screw. When it sets up, remove the screw and clean off any excess vaseline. You will then have new threads.
    Or plan B, fill the hole with JB and retap it with a bottoming tap.
    http://www.youtube.com/watch?v=Dj_oEx4-Mc4
    The world of people goes up and
    down and people go up and down with
    their world; warriors have no business
    following the ups and downs of their
    fellow men.
