At the risk of many people climbing all over me… I have always used a 3.25 x 10 boot inverted at the top of the wall to a 6″ round pipe. Then I purchase pre-insulated duct to the roof vent or gable vent depending on the situation. And no I am not talking about roof vents for the attic space but the type intended for this purpose. It reduces the volume a bit ( by about 1/3 ) but on a short run it has never caused a problem that I know of. Just try to be sure both ends in the attic are well sealed to keep that humid air outside where it belongs.
SteveM
At the risk of many people climbing all over me... I have always used a 3.25 x 10 boot inverted at the top of the wall to a 6" round pipe. Then I purchase pre-insulated duct to the roof vent or gable vent depending on the situation. And no I am not talking about roof vents for the attic space but the type intended for this purpose. It reduces the volume a bit ( by about 1/3 ) but on a short run it has never caused a problem that I know of. Just try to be sure both ends in the attic are well sealed to keep that humid air outside where it belongs.
SteveM
>I am installing a new range hood in my kitchen. It will be ducted through a cold air attic, terminating with a roof cap. Duct will be 3.25 x 10. Do I need to insulate this duct to prevent condensation. If so what type of insulation would you suggest? Any other tips would be welcome.
*Condensation will definitely be an issue -- say when boiling water on a cold January day -- be sure it has somewhere to drain to. Any fireproof insulation should be OK. i believe there are code requirements on the thickness of the metal and such.
>Thanks for the info. I ran 3.25 x 10 to the roof cap. Taped the joints with foil tape. Wrapped the duct with R-6.7 foil covered, flame resistant fiberglass duct wrap. Then taped the wrap with the foil duct tape. Entire run is about 14 feet. I think I've covered the bases.
