I want to build a roof over an existing deck, making it into a porch. 5’wide, 25′ deep; standard construction, 2×10 ledger bolted to the foundation, 4×10 beam, 23 2×8 x5′ joists. The beam sits right on the piers, which rise 12″ above grade; no posts. Problem: the beam is not plumb, has a very slight tilt – certainly no more than 3-5 degrees – outward. I worry that because of the angle, the weight of the roof, fully loaded with Chicago snow (I figure total weight – 3,000 lbs) is going to have a certain vector component outward, tending to tip the beam out and down. With such a small angle I can’t imagine it’s that much of an outward force, and it would be spread out over 23 joists holding the beam in – does anyone have a strong opinion on whether I need to plumb the beam before putting the roof on? Am I right in assuming the joists actually are helping hold the beam in, and not adding to the problem by pushing the beam out with their weight?
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
You are right that the joists help hold it. I can't see what other factors might be variables here but whatever snow is going to load on it is loading to the deck right now with a roof over it so added is negligable. You can add some kickers or hardware to keep it from going further.
Still nervous? Post us a picture or two.
