I need to place a recessed can light centered over a kitchen sink. However, upon inspection, I discovered an I-joist in the ceiling directly above (running perpendicular to sink wall). What options do I have?
A mini on each side.
Quittin' Time
beats moving the sink!
and just why is there always a perfectly center joist exactly where I planning on putting a can?
seriously ... if ya tried yer hardest ... you'd never get close to the "random perfection" that I've been running into ...
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
I'll tell you what, that x-ray vision stuff would be the ticket. I've had 'em move layout just to put one in the way. Worse than what this guy describes is when they run the other way, parallel with that outside wall. You move it out into the room and it's too much outside the uppers run...........in towards the wall, and it's too crammed. Surface mount for sure, or maybe a nice pendant.
I've found something in most of the kitchens that screams "screw me". Get all the cans layed out, knowing layout and even drilling probe holes in case you have to cheat it over and what do you find when you cut that hole? Copper servicing the upstairs bath not even located over the kitchen. You ever ask the plumber to jog copper around a can?
New construction is hard, remodeling is impossible.
That's why we love it.
Quittin' Time
this kinda stuff seems to happen to me too.......I used to just call it bad luck, but more like old Murphy trying to screw you over---
2 minis sounds like the key
Be flexible
When in doubt, get a bigger hammer!
yeah ... I love that one ...
the old "hidden pipe" trick.
works best like ya said ... after U stud scan ... then poke ... bent hanger ... little test hole ... then cut her wide open ... and BAM!
Buck Construction
Pittsburgh Pa
And welcome.
Quittin' Time
How about a surface-mounted fixture?
Al Mollitor, Sharon MA
Agree with Calvin.
You should have planned for two anyway, better illumination and less shadow.
Then you would have run into two joists and you'd end up putting one right above the sink which is what you want in the first place.
