Reenforcing I-joists
MSA1 | Posted in Construction Techniques on February 14, 2005 10:20am
I read somewhere (i think it was here) about cutting down the flex in an I-joist floor by adding some plywood to the webbing. Can anyone refresh my memory?
I’m preparing to start a basement job and the client is complaining about a bouncy living room floor. Id’ like to tackle the bouncy floor before starting the basement.
  1. firedude | Feb 14, 2005 10:54pm | #1
    any blocking tying the i-joists together? - also - check with the i-joist makers for their solutions - certainly not the first time this problems come up
    1. MSA1 | Feb 15, 2005 05:23am | #2
      Honestly I cant remember if there is blocking or not. I know that would help but I was also considering building up the webs.
  2. FrankB89 | Feb 15, 2005 05:29am | #3
    When you purchase one or a truckload, there should be included an installers sheet that will clearly explain how to do what you want to do.
    The Mfgr's guidelines are important if you want to do it right and maintain warrantee.
    1. MSA1 | Feb 15, 2005 05:42am | #4
      Thanks, but i'm not buying the I-joists. The house is already built, i'm doing the basement.
      Sounds like no matter what I need to contact the manufacturer.
      Anyone else?
      1. DanH | Feb 15, 2005 05:45am | #5
        Look for a mfgr's stamp, find their web site. Likely the info is online.
      2. FrankB89 | Feb 15, 2005 06:07am | #6
        If your local yard handles BC-I's (Boise Cascade)or TG-I's (Trus-Joist, AKA Weyerhaeuser), I'm sure they will gladly give you the pamplet....it's a single sheet foldout, made for the jobsite.
  3. byrnesie | Feb 15, 2005 07:36am | #7
    What about possible framing deficiencies- like a load bearig wall on top or a heavy tiled bath wall above a single joist? Maybe you'll find an area where a joist needs doubling up. Also, when thats done, strapping the ceiling will help keep the joists from torqueing. Are you putting in any partitions in that could help- sometimes you can get a header in above a built in entertainment center.
    1. MSA1 | Feb 16, 2005 05:21am | #9
      Nope none of that. Its a single story condo and the "big bounce" problem is in the living room. Mostly open floor. Sorry I cant remember all the important specs, I think its a 12' span and the joists, 16"o/c look to be about 10" tall.
      I was brought in to build the basement, the floor bounce was sort of a side discussion. Thats why I dont have all the specs.
    BossHog | Feb 15, 2005 05:40pm | #8
    There have been several threads about this issue over the years. Try the advanced search and you could probably coem up with a whole bunch of them.
    Bumper sticker in the year 2100: DISCO STILL SUCKS
Two Ways to Test Windows
  • The New Old Colonial
