are there places that reenamel cast iron?
yes
The sink looks great it just needs some sheen, is that possible with a re-enameling kit? Could you or anyone tell me what company they have had success with and how to get in touch with them. HELP! thank you...
If it is not chipped, it might just need to be cleaned well. Muratic acid will do the job. You need to wear rubber gloves and faced protection. Mix according to directions with water carefully to about ten percent..
I think the sink may have lost its sheen. it looks as if the top layer of enamel is missing and there is no sheen but the color is nice, it just looks shratched and worn. I also recently used muradic acid to clean a porcelain sink with great results, but on the container it said not to use on enamel.
