refrigerator slow water
tylercc | Posted in General Discussion on March 16, 2014 02:44am
So my refrigerator that is like 8 years old has  now started slowing down on how much water come out after I moved in to a new house. I believe the problem is a bad water inlet valve because I test the water coming from the house and at each of the connection points(water inlet valve, and water filter). And only When I was testing the water inlet valve did the water pressure go down. So does this mean it definitely a water inlet valve? It is a whirlpool fridge/freezer model ED5FHGXNQ01
  1. tylercc | Mar 16, 2014 04:37pm | #1
    Nope
    1. calvin | Mar 16, 2014 05:38pm | #3
      tyler
      if it should happen that it might be the saddle valve-
      shut off the water b/4 it.
      remove the piercing needle from the valve-cut the tip off shorter (not so short it won't shut off............) .
      When retracted-open- the point won't restrict water flow.
  2. jeff1955 | Mar 16, 2014 05:08pm | #2
    most likely is inlet (supply) shut the water off (usualy in basement )disconect the1/4 supply open back up and see if you get good flow t type saddle valves clog up i think you will find this is your issue
    spclark | Mar 17, 2014 07:18am | #4
    Saddle Valve's...
    ... the first thing I'd check too. Had one on a humidifier where the needle had broken off & was 'clogging' the hole it made when installed. Discovered after four, maybe five years of operation it was kind of a mystery as I'd not messed with it since the installers put it in so how the busted-off point got back into the hole is still a mystery to me.
  4. tylercc | Mar 17, 2014 10:35am | #5
    Aloough sense I have good water flow coming from the supply line that would mean it can't be the saddle valve right?
    1. calvin | Mar 17, 2014 11:56am | #6
      tyler
      good flow after supply-saddle valve should be ok.
    2. DanH | Mar 17, 2014 03:51pm | #7
      You can have good flow for a second or so and then have it cut off.  This is typical of the bad GE filters, and likely could occur with the saddle valve too.
      The way to make sure the saddle valve is not a problem is to shut off the water downstream, remove the saddle valve core, and then run a drill bit through to slighly enlarge the hole the valve punched.
New House, Old Shell
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
