I have removed an old Window Type Airconditioner that was installed through the wall underneath a picture window. How can I best remove the adjacent steel siding so that I can replace plywood sheeting next to opening that has water damage?
I plan on installing a piece of 3/4″ plywood to cover the hole and then install replacement steel siding overlapping where I cut to gain access. Any advise would be appreciated as I have never worked with this steel siding before.
Thank You
Frank
What kind of steel siding? Is it the kind that looks like clapboards or vertical?
It is seemless clapboard type that runs horizontal across the wall.
