Removing a sheared Tapcon
| Posted in General Discussion on October 30, 2007 04:29am
While driving in a Tapcon, it sheared off just below the surface. The electrical box that I’m trying to surface-mount with these is, of course, in a tight spot so I can’t reposition the box and start over. How do I remove the sheared Tapcon? Would a reverse bit work? Can I just drill it out? What about fastening the box using something like a urethane adhesive (e.g. 3M 5200)? Thanks.
    jagwah | Oct 30, 2007 04:54pm | #1
    They make an abrasive hole saw mostly for ceramic tile. Just a thought but if you used the 1/2" bit you might get low enough to break out the tapcon then use a two part epoxy anchoring adhesive to fill the hole and lock in the new tapcon in place.
    Just a SOTP, TOMH idea.
    Edited 10/30/2007 9:54 am by jagwah
  2. MikeHennessy | Oct 30, 2007 04:57pm | #2
    Uh, why not just drill a new hole in the box? Way quicker than trying to free up a busted tapcon.
    Mike Hennessy
    Pittsburgh, PA
    1. Norman | Oct 30, 2007 06:06pm | #3
      Yup, drill another hole. Tapcons are hard and it will be a long time drilling thru them. The right glue would probably work, but I'll bet code says no-no.
      If the tapcon sheared, you didn't drill the pilot hole deep enough. There has to be room at the end of the hole for the chip waste created by the screw.
      Good luck.
      1. wane | Oct 30, 2007 07:51pm | #4
        and check the box for the maximum depth, 1 1/4", me thinks ..
    2. MSA1 | Oct 31, 2007 02:01am | #7
      That was my thought.
  3. fingers | Oct 31, 2007 12:37am | #5
    Either drill a new hole in the box or use an existing hole in the back of the box and use one of those thin expansion anchors.
  4. JTC1 | Oct 31, 2007 01:14am | #6
    Ditto what Mike Hennesey said: drill a new hole in the box.
    Drilling out a Tapcon ............ I wouldn't even know where to start, and probably would not like it if I did.
    Jim
    1. Gary | Oct 31, 2007 02:16am | #8
      Thanks for all of the advice. New hole drilled deeper. Cleaned out with vacuum cleaner and air blast. New Tapcon placed without problems. Not as purdy as the first attempt, but, hey, it's only an outlet box. Happy Halloween.
Two Ways to Test Windows
  • The New Old Colonial
