When ever I have renovated or repaired a house with stippled ceilings I have found the easiest way is to scrape it bare and start over. What can be done if the stipple is painted over and has anyone found a good method to match the existing texture. I have never come across anyone who can ‘match’ stipple without it looking like a patch.
"I have never come across anyone who can 'match' stipple without it looking like a patch."
Yes and no. I can repair it to look like new , but it wont be the same .,the same is gone basically.
Of course stipple has been painted and its not worth stripping to me or most of the time the customer.If its been stippled with UGG joint compound its there as far as Im concerned. If it has to resemble what it did before , I box it with a 12 inch float box 10 inches apart and set it on feather. Come back in a few hours and box the 10 inch spaces on feather. Now you have a slick ceiling thats primed well if you want to paint it or stipple over it . New looking work either way.
On the other hand , you can mask the patch and shoot it to match as close as possible. Remove the masking paper and blend it with a feather brush. Then shoot the entire ceiling with another stipple and it will look like new work , but it wont match the rest of the house. All depends on the customers dollars. For fixer uppers , low cost clients, and rent houses , this method flies. It does not look like a patch , but it doesnt look like the rest of the other rooms and under flat paint , it doesnt stand out even then.
Tim Mooney
Edited 12/5/2004 11:24 am ET by Tim Mooney
Tim,I never thought of masking off excellent suggestion.
Well, masking off is the only way to repair a ceiling that has acoustic texture. Ive repaired several and needed to come back the next day to shoot over the patch and the client would call and say , "its good". Let me pay you now and dont come back.
Of couse I knew they were getting by cheaper , but Ive seen some pop corn patches look good if the original was pretty new.
Ive never even tried to patch stipple with a patch alone and wouldnt . I agree with you on that . Theres not enough texture there to cover anything.
Tim Mooney
I "flattened" a stippled bathroom cieling a while back.
Went out to the shed and found a Hoe
hoed off the high spots
then put on a coat of easy sand trowweling in one direction
made a bunch of parrallel ridges
Sanded the high(or low) spots
next coat I trowelled in the perpendicular direction.
valleys filled in nicely.
one more sand and a 3rd coat and you would never know the diff.
Mr T
I can't afford to be affordable anymore
