I’m cleaning a house right now that is going through renovations. The owners have removed the sliding doors from an acrylic surround tub, and there is caulking left over on the surround. Is there any way, other than a flat razor, to remove this caulking? Any tricks or ideas would be greatly appreciated.
hi kim
i have used a plastic spackle knife it is time consuming but it does work just be carefull of the angle you hold it at . try and avoid short scraping strokes, long scrapes and holding the chaulking as you move the knife has seemed to work bets for me . Once you get into it you will gain the nack to it
I have heard that heating it up with a hair dryer helps (so long as you don't burn the fiberglass, of course) but I have not seen it done with my own eyes.
i have used a plastic spackle knife with commercial caulk remover to remove silicone from ceramic tile and fixtures. you may have to check the label, and do a test patch to be sure, but the technique has worked for me.
hope this helps. rich
I have used a new stanley knife bade. Works well but you need to be careful. Otherwise I use something plastic to remove the bulk, then give it good rub with Ados sovent N. this softens it, letting you get even more off with the scraper.
A few repeats with the solvent and it is clean. Use good ventilation though cos that stuff is pretty fierce. So far I have used it on all sorts of baths and showers with no problems. Only thing I found that doesnt like it is fibreglass.
Just to be safe, test a bit on a hidden area.
Everything, 100% of it, depends on how you look at it.
DW
Dap makes a product....can't remember the exact name.....something like "Caulk be Gone".
Kinda messy, but it does dissolve the stuff if you have a giant bead.
