In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
removing glue from wood floor
| Posted in General Discussion on August 30, 2004 03:49am
We have purchased a 20 year old building.  It used to be a church.  It had carpet glued on top of fir plywood.  What can I use to remove the glue so that I can put paint on the floor.  My building is 30 X 60.
Harv
  1. FastEddie1 | Aug 30, 2004 04:29am | #1
    Sandpaper.  Rent a floor sander.  Room that size, with no walls or anything in the way ... ought to be ready for apaint in less than a day.
    Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
    Dinosaur | Aug 30, 2004 05:55am | #2
    I concur with Ed. Rent a floor sander. Get the new random-orbit type instead of the old drum-style sanders; it'll make your life a lot easier and the job a lot better looking.
    Dinosaur
  3. HeavyDuty | Aug 30, 2004 05:56am | #3
    Get more sandpaper than you think you 'd need, the glue gums up the paper pretty fast.
  4. gordsco | Aug 30, 2004 06:10am | #4
    Fir plywood aint gonna sand too well. Chances are you'll burn through the veneer and there will be splintering. You can fill the splinter holes and glue down some of the frays before painting. This is what you will have to fix if you can get throught he carpet glue with a sander. The carpet glue is going top heat up and plug many sheets of sandpaper before you even get to the veneer. Unless of course you use a heavy grit, in which case start reading the top of the page.
    Another option is to scrape off the glue with a paint scraper. Very tedious work, and practically free if you don't count labor.
    1. FastEddie1 | Aug 30, 2004 07:18am | #5
      and practically free if you don't count labor.  Hey!  That sounds like some of the jobs I bid.Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
  5. DanH | Sep 01, 2004 07:14pm | #6
    You can try a hot air gun or torch to remove the thickest buildups, or various types of paint remover. Sanding will probably be required as a finishing touch, though.
    But if it's plywood the simplest thing may be to simply remove the thickest spots and then lay another layer of ply on top.
    1. HeavyDuty | Sep 01, 2004 08:12pm | #7
      I thought of that too...but labor is free and material is not. :)
DeWalt Recalls 12-in. Sliding Compound Miter Saws
Purchasers of certain models should stop using the saw immediately and contact DeWalt to receive a free repair kit.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
