writing this post again because it didnt show up the first time. I will be installing 3 new Andersen double hung windows in a couple of weeks in the middle of a gable end wall of a home. My question is the outside of the home hasHardi plank siding clap boards with a 4″ exposure. How do i remove the siding ineed to remove to install the windows without totally trashing every peice. I need a techneich to remove the areas in the feild that need to be removed so i can properly install the windows and seal them from the weather, i have never worked with this type of siding before. Any and all suggestions that will help me get the job done right are welcomed Thanks, Ricky
The FHB Podcast crew offers advice on re-insulating the south wall of an old Pittsburgh mill home.
circular saw. I cut the stuff with a hitachi saw made for this, with a dust bag. You'll want at least a carbide blade, if not a diamond ($35 minimum) and a respirator. Make your cuts, and pull the siding off. It will pull through the nails easily. Then pull or pound in the nails and you're good to go.
