removing ink from a wood floor
pino | Posted in General Discussion on August 15, 2006 07:18am
Any ideas what to use in removing ink from a poly’d had wood floor? My wife broke a pen and got blue ink all over the floor. We tried a few household cleaners and they all seem to get some of the ink, but smear the rest.
Any suggestions?
    PeteDraganic | Aug 15, 2006 07:44pm | #1
    Ink remover?
    Seriously, I think that print shops carry ink solvent.  Call one and see.
    The difference between stupidity and genius is that genius has its limits. -Albert Einstein
    http://www.peteforgovernor.com
    PeteDraganic | Aug 15, 2006 07:47pm | #2
    I just read that Isopropyl Alcohol works for ink removal
    or you can order the ink remover at the link below....
    http://www.bettymills.com/specials/mots/motsenbockers.html?type=GoogleAdWordsSearch&gclid=CI3Fip-S4oYCFSCCSQod2COLAg
    jarhead | Aug 15, 2006 07:57pm | #3
    Methylated Spirits which is ethyl alcohol. Also try acetone, naptha, methanol, try vasaline rubbed in the stain for a couple of days for a less intrusive approach. I would as pete said try the alcohol first, you should have that laying around.
                                  Semper Fi
    Edited 8/15/2006 1:23 pm ET by Jarhead
    1. pino | Aug 15, 2006 08:23pm | #4
      Thank you both for the suggestions. I'll give them all a try.
      1. hmj | Aug 15, 2006 08:49pm | #6
        Acetone could bring up the poly as well; I know from experience.
          jarhead | Aug 15, 2006 09:11pm | #7
          Once cured, I wasn't aware that Polyurethane had a solvent. Once the finish had crosslinked I assumed not much could change the finish. Repairs are started out with sand paper where as in a laquer finish all you have to do is wipe with the appropriate solvent to break it down. It has been a while since reading his book (Bob Flexner) but one of the ways to determine the type of finish you have is to use various "solvents" and if none did soften the finish you were left with polyurethane. I can't reference the book due to being at work. I'll look when I get home.
                                              Semper Fi
          1. hmj | Aug 15, 2006 09:30pm | #8
            I spilled some acetone on a poly'd jatoba floor and it bubbled and peeled. Believe it was water based poly.
            jarhead | Aug 15, 2006 09:52pm | #9
            oooh, bet that hurt. I don't know if the water base has anything to do with it but when I get to the house I'll try to look it up.
                                                  Semper Fi
          3. hmj | Aug 15, 2006 10:02pm | #10
            It was some splashes and a ring when I set the can down in a hurry- bled through a canvas drop cloth. Laquer thinner and Famowood solvent did it too. Sanded w/ 400 grit and "patched" it with a few coats of minwax wipe on poly. This was in a closet so I don't know if I could have pulled it off in a foyer or somewhere more conspicuous...
  4. JohnD1 | Aug 15, 2006 08:25pm | #5
    What you have to do is get the ink into something that you can remove.  Simply wiping it with something that dissolves it can cause it to also soak into the wood if the coating is bad.
    There are a lot of cleaning devices that consist of a solvent plus a powder.  The solvent dissolves the stain, and as the solvent evaporates from the top of the powder, the bottom solvent is carried into the powder.  Then you sweep it up and throw it away.
    If you have talcum powder (NOT!!! the cornstarch stuff) you can do the same with your own cleaners.  Just choose one that seems to soften the ink; mix it with the powder and put the poultice down.
  5. Danno | Aug 16, 2006 12:43am | #11
    Seems like I remember some hint about using hairspray on ink on clothes--maybe that would work--less likely yo damage the poly than some other solvents.
  6. JLazaro317 | Aug 16, 2006 12:58am | #12
    I had to remove ink from some cabinets thanks to my 2 year old. I think what removed it was either WD-40 or Deep Woods Off. We tried both and one was better. My wife has a book about how to remove all kinds of stains and that was the recommended remedy.
    Good luck,
    John
    J.R. Lazaro Builders, Inc.
    Indianapolis, In.
Use a Rainscreen to Protect Siding
Joe Cook and Travis Brungardt detail the benefits of using the Slicker Max Rainscreen from Benjamin Obdyke to protect the siding of the FHB House.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
  • The Right Footings for Strong Foundations
  • Tool Test: Compact Cordless Routers
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
