Removing lumber stamps?
dpbellus | Posted in General Discussion on June 26, 2009 11:39am
I am in the process of building a deck.  I’m using pressure treated 2×6’s for the decking.  Some of the boards have the grade, i believe, stamped on them.  How do I remove this?  Sanding? Bleach?  I don’t want them to show when I stain it.
  1. shtrum | Jun 26, 2009 11:55pm | #1
    Circular pad on the drill takes them off.
    'Course, turning the boards over so the stamps don't show is easier.
    1. dpbellus | Jun 27, 2009 12:07am | #2
      I've been putting the heart side up so (hopefully) the boards will crown instead of cup when they start to move.  The stamps are sometimes on the heart side.
      1. Piffin | Jun 27, 2009 01:08am | #3
        Problem with that in PT is the spoon sized slivers it throws into your feet.Any sander will take the marks off.
        1. DonCanDo | Jun 27, 2009 02:33am | #4
          Yes, they sand off easily, but the OP should be aware that any sanded areas will take stain differently.  Of course, the difference between any 2 boards could easily be greater than the difference between sanded and non-sanded areas, but it's still an aesthetic issue and something he should be aware of.
            CapnMac | Jun 27, 2009 03:38am | #5
            Uhm, maybe I'm dense, but how much penetration into PT lumber will a wipe/brush stain have?
            I'm not coming up with a color complementary to that PT-green shade, either, but I've not been very imaginative all day, today.Occupational hazard of my occupation not being around (sorry Bubba)
            Huck | Jun 27, 2009 03:42am | #6
            hahahahah - you said "its an aesthetic issue"!!!!View Image
          3. Piffin | Jun 27, 2009 01:56pm | #8
            2-3 weeks of sun evens it right out.
        Huck | Jun 27, 2009 03:45am | #7
        I once saw a public boardwalk where every single plank was screwed down heart side down - they all cupped over time.  Job security, I'm thinking.  BTW, how could you be using pressure treated lumber for decking and be worried about how a stamp would spoil the looks?View Image
        1. Piffin | Jun 27, 2009 01:59pm | #9
          Be kind now;)
