Removing/reusing trim – good tip
doitall | Posted in Construction Techniques on May 2, 2005 08:27am
I’ve never seen anyone post this tip, and it’s so simple that I hate to take all the credit for it.
I used to remove trim and either clip off or pound back the existing finish nails.  Now what I do is keep either a roto zip with an angle head attachment and metal cut-off wheel, or a 4-1/2″ grinder with a thin metal cut-off wheel handy.
I zip those protruding mails off on the back side of the trim.  Very quick and very clean.  Then I just shoot the trim back in place when I’m ready with a 16ga. or 18ga. finish nailer.  Try this sometime – you’ll wonder why you never thought of it ( but then again, maybe you did).
  1. Shep | May 02, 2005 09:11pm | #1
    When cleaning up trim for reuse, I use a pair of bull nose pliers and pull out the nails from the back side of the trim.
    I find this way is quick and easy, and I'm usually carrying the pliers, anyway.
FHB Podcast Segment: Waterproofing Below-Grade Foundation Walls
Learn about the pros and cons of waterproofing vs. damp-proofing foundation walls.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
