I have a Powers-Fiat Shower Stall Model # MS 336, this is a one piece unit with a built -in ceiling sort of an apronless bathtub turned upright. I just discovered an approximately 3″ long crack on the entry side with a short branch crack. I have tried to locate the manufacturer regarding possible repair recommendations but have been unable to locate them.
Therefore, I’m asking the knowledgable experts of Breaktime for any repair suggestions you might have on this topic.
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
If you can get to the other side of the crack, dunk some fiberglass insulation in polyester resin and plaster it against the back side of the cracked area. A good tub and appliance finish repair person can color-match and refinish it from the front side to look good as new.
*There are specialists that repair this sort of thing. Try contacting a plumbing wholesaler in your area and ask if they can recommend someone. When done right, you won't even be able to tell where it was repaired.
*A new tile shower receptor will fix your prob.
*You said it. They will be smart if they follow your advice.
