In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Replacement window or not?
emaxxman00 | Posted in General Discussion on July 24, 2010 08:53am
I’m trying to figure out if I have a replacement window or not.  From the inside, I removed all of the trim work (just drywall) around my bathroom window.  Not a lick of insulation between the RO and window frame. There are only 2 screws on each side holding the window to the RO.  On the top, there are no screws and I can see the backside of the vinyl siding.
If this were a new construction window, would it not have a nailing flange or some sort of capping on the top side?
I’m renovating the bathroom and would like to upgrade the window to a new one.  It’s an older double hung, double pane window which still works OK but is not great.  This would be a perfect time to replace it.
I’m trying to figure out how big of a job it would be for me to remove the window and install new.  If it requires extensive work outside, I may skip it since it’s not a necessity,
  1. calvin | Jul 24, 2010 09:01pm | #1
    emaxx
    Since you have vinyl siding it will be work but not necessarily out of your range of talent.  The beauty of vinyl is it's flexible in the warm weather.  You could remove enough-number and pencil line the tops of the courses for later reference.  Make sure your new construction window with flange is at least as big, preferably a bit wider and taller yet within your rough opening dimensions.  Mount the window so the siding will fit it and then re-side to it.
    Detail the window install so no water entry.
    Both siding and window install information can be had at siding companies websites and of course your window supplier.  I suppose FHB even has books on the subject.  Wolverine siding used to have a very good online and in print instruction booklet.
  2. DanH | Jul 24, 2010 09:49pm | #2
    Not unusual even for new construction, depending on the era and how earnest the inspectors were.
    Again, not that unusual even for new.
    If the vinyl is replacement siding then this suggests the window was installed as a part of the siding process.  But if the siding is original likely the window is too.
    The first question you should ask is how good is the window?  If it seems to be a good quality window, operates well, seals well, etc then you should probably just peel back the siding a bit and install rubber membrane flashing, then seal and insulate well from the inside.  If it's a lousy window then now is a good time to replace it.
  3. Clewless1 | Jul 26, 2010 09:06am | #3
    FYI ... often there are no fasteners at the top. In fact many window manuf. have labels on the top flange to NOT nail the top flange. I think the notion is that any stress on the header or from above might get transferred to the head of the window. Also, most flange installs recommend that you don't drive the fastener 'home' ... allow the flange/framing to move a bit independent of each other.
Innovative Design in Affordable Housing
A barbell layout comfortably organizes this small, single-family home into its extremely narrow footprint.
  • Podcast 533: Missing-Middle Housing, Collateral Damage From Demo, and Midwest BS Symposium
  • Podcast 533: Member’s only Aftershow — Training for Tradework
  • Insulation Project Guide
  • Insulating a Roof: Getting Higher R-Value
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • Issue 309 - Aug/Sept 2022
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
