I am considering taking a few jobs installing replacement windows for a friend of mine. Though I have installed quite a few windows, they have all been new construction models. Any pointers on different techniques I should be aware of with replacement vs. new construction installation?
Greetings Dylan, As a new poster Welcome to Breaktime.
That subject has been addressed here on Breaktime a number of different times in the past.
In the event you fail to receive the information you desire, you might find it in the archives.
If you scroll down in the lower left corner of your screen there is a search function that will take you to previous threads dealing with whatever you type in the search bar.
If you type in 'window install' or other keywords of the subject matter you'll get a supply of data from those old threads.
Cheers
This is purely a case of alien identity
Replacement windows go in easy...usually 2 screws per side, and a stiffner plate that you snug up by turning a set screw. Biggest thing...measure, measure, measure before placing your window order. Know how much the window manufacturer "cuts down" off your specified measurement beforehand so you can spec the right size correctly. Many vinyl windows are "built" on the 1/4 inch scale and they deduct a 1/4 inch from both the specified width and height unless you tell them differently. Example...I spec a window to my supplier and tell him I want the window measurements I gave to be 'EXACT." If I spec it that way, I will lose the 1/4 inch off the side and height. If I say I want the measurements to be "TIP TO TIP" the manufacturer will not cut down the window at all. ( funny how "exact" isn't exact anymore, isn't it?)
Anyway, good luck. Just get to know your product before trying to sell and install it. Know how to use a bending brake, and bend coil stock accurately....most replacements involve some exterior wrapping.
Davo
