Replacing drill chuck
netanyahu | Posted in Tools for Home Building on February 26, 2007 04:15am
I have an old  Millwaukee electric drill that  has a 5/16″ chuck.  I want to replace it with at least a 3/8″ chuck so I can use it to mix joint compound.  Has anyone had any luck doing the same? Thanks
    ToolFreakBlue | Feb 26, 2007 04:29am | #1
    I put a keyless chuck on an older corded Makita drill motor. Easy.
    Tried it on an old Makita cordless with no luck. I couldn't get the retaining screw out of the old chuck. Had a socket type (allen head) screw and it got rounded out. Not worth the trouble to continue on that drill.
    I wonder how long your motor will hold up mixing joint compound if it only had a 5/16 chuck to start.
    TFB (Bill)
    1. netanyahu | Feb 26, 2007 04:38am | #2
      I know I could replace the chuck easily enough, but I was wondering about going up in size.  As for the motor holding up, I don't use it very often, so I'm not really worried about that.  The drill is prety old and beat up, so mixing mud is all I really want it for anyway.
  2. netanyahu | Feb 27, 2007 01:40am | #3
    bump
  3. DanH | Feb 27, 2007 02:25am | #4
    Depends on whether it's a standard size/configuration shaft. If so then you should be able to install a new generic chuck, or one scavanged off a non-functioning drill. If not, not.
    Note that if the old drill is not reversible then it generally won't have the lock screw down the central shaft -- it's held on by a simple left-hand thread. The standard scheme for a reversible drill is the same left-hand thread on the chuck, but a right-hand screw through the center of the chuck jaws and into the shaft.
    Getting the chuck unthreaded is of course a "challenge". Some come off quite easily, others are essentially impossible to remove after decades in place.
    But if you have to buy a new chuck it's probably not worth it. You can buy a new cheap drill for under $20 or so, or pick one up at a garage sale for $5.
      Sphere | Feb 27, 2007 03:06am | #5
      I found the easiest way to get the chuck un screwed is to chuck up an allen wrench and give it a SHARP rap. That works pretty well most of the time.
    JeffBuck | Feb 27, 2007 03:31am | #6
    bet ya burn it out pretty quick.
    any "used tool" stores near ya? I'd look for an old 1/2" drill ...
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
