replacing Homasote w/ sheetrock
| Posted in Construction Techniques on August 7, 2003 06:13am
Hi gang,
I gutted a room today that had been finished with Homasote wallboard which is that old cardboard type of wallboard.  Anyway, the stuff I pulled off was 7/16″ thick.  Would anyone like to weigh in on whether I should use 3/8 or 1/2″ sheetrock to refinsh the walls?  I could see either one working ok with a 1/16 difference in thickness around the windows and doors.
Opinions?  Thanks for the help.
Bart
  1. WayneL5 | Aug 10, 2003 09:12pm | #1
    3/8" sheetrock will tend to wave between studs, 1/2" is standard for walls and will remain flatter.  If it's a bargain job or an out of the way place like a closet or laundry room then 3/8" will work, but I would use 1/2" on the wall and 5/8" on the ceiling anywhere where the apearance would matter.
    1. MarkH128 | Aug 11, 2003 01:20am | #2
      Ditto
