Replacing second floor in garage
Rodney_The_Novice | Posted in General Discussion on August 8, 2020 01:43pm
So I have a garage with old rotting 1×6 for the floor. The joists are 2×12 rough cut and I have a metric boatload of 2x4s that I have no use for (came with the house when I bought it). I was wondering if I can replace the 1×6 flooring with stud grade 2x4s as flooring instead after making sure the joists are sound. Is there any drawback here that I am missing?
  1. oldhand | Aug 08, 2020 03:05pm | #1
    Square edges will have some cracks showing at some point. Install will be difficult. Other than that maybe not such a bad idea if the job won't need inspecting.
  2. Rodney_The_Novice | Aug 08, 2020 03:14pm | #2
    Hmmm I hadn't considered that codes might have a problem with it. I didn't know there were codes against over building something haha.
  3. Frankie | Aug 09, 2020 09:08pm | #3
    Hmmm... Traditional subflooring is tongue and groove so loads are shared with adjacent boards/ sheathing. 2x4 are narrower than typical subfloors so it would be difficult for a load to only be on a single "board" but the load per board won't be uniform with adjacent boards. Add a spline and groove and you're back in business.
    Frankie
New House, Old Shell
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
