replacing window sill
nkhandyman | Posted in Construction Techniques on May 25, 2005 08:37am
I have been asked to replace some rotted wood around a house. Some of the wood (from the outside) is part of the window sill.
Any suggestions about the best way to remove the old and install the new without taking the window apart?
Paul
  1. Shep | May 25, 2005 09:20pm | #1
    I've had some success doing this two different ways-
    If only the outside edge is rotted, I'll cut that off and glue and fasten a new piece in it's place.
    If the whole sill is rotted, I'll use a recip saw to cut it out in pieces, being careful not to cut the window jambs or interior stool. I then fit the new piece, and use construction adhesive to hold it in place, with a few well placed nails or screws to help.
    I also like to prime all bare wood that's not going to be glued before I put everything back together.
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
