I plAN ON BUILDING A RETAINING WALL ACROSS THE BACK OF MY PROPERTY, ABOUT
110 FEET BY 4 FEET HIGH, USING 6X6X8 PT AND INSTALLING DEAD MEN EVERY FEW
RUNS. DOES THE FIRST RUN HAVE TO BE ON ANY TYPE OF FOUNDATION, OR CAN I
INSTALL IT ON GRA
Jim -
Information I've been getting suggests the first run of base beams be below grade on gravel.
I'm about to embark on a similar project but not quite as ambitious as yours.
Good luck !
*Hi Jim,Ideally, you should be below grade on the first two runs and over a bed of gravel. The backfilled side should have a drainage pipe inbedded in crushed stone and backfilled with sand or gravel so as to not trap water.I don't know the climate your in or the type soil on your property, so I can't be too specific.Gabe
*Sounds like Gabe and Alan are right on the money. FWIW, Scott McBride wrote an article on timber retaining walls in FHB issue 124, pp. 102-105.
*Thanks all for the input!
