retaining wall question
tmaxxx | Posted in General Discussion on July 19, 2006 11:14am
howdy all.
i have to replace a retaining wall that rotted away.  the HO wants an allen block type wall.  the wall will be 6ft tall 10ft wide with 4ft 90 deg forward turn on the right end and the left end will butt against the concrete foundation.  the mfg claims the block can stack to 6ft, but im wondering being only 10 ft wide and that high if i should connect (with epoxy and rebar) the left side to the concrete foundation or will it hold ok?
Tmaxxx
Urban Workshop Ltd
Vancouver B.C.
cheers.  Ill buy.
  1. TLE | Jul 19, 2006 01:18pm | #1
    I would connect it - IF the retaining wall has a footing depth similar to the foundation you are attaching it to.
    It won't do if the retaining wall will be lifted by the frost independant of the foundation.
    Terry
    PeteDraganic | Jul 19, 2006 11:53pm | #2
    you could use a tieback of "geocloth" at 4 ft high but you'll obviously have to excavate and replace more dirt.
    The difference between stupidity and genius is that genius has its limits. -Albert Einstein
    http://www.peteforgovernor.com
