Roof Rafter Eave Details – New and Existing
I am adding on to my existing home. The existing portion built in the 40’s has a 4:12 hipped roof framed with 2×4 roof rafters at 24″ OC. The new portion matches the existing, but with codes nowadays, 2×8 @ 24 OC rafters will be required. I want to keep the ceiling heights the same throughout the house, which are already just at 8′-0.
Assuming the wall top plates remain at the same height throughout, how will the new 2×8 rafters sit on the top plates without adding a soffit at my interior wall corners to cover the bottoms of the 2x8s? Will the 2x8s get cut down to a 2×4 at the top plate? What is typically done to match 2×4 rafter construction with newer 2×8 rafter construction?
I am thinking that using roof trusses may be the way to go to eliminate this problem.
Thanks in advance for your responses.
your thinking is correct. Trusses will solve your problem.
regards
mark
