Rotten Sill Needs Help!!
| Posted in General Discussion on October 5, 2000 04:52am
Tim, I just quoted the same job ona house built in the 1800’s, with the exception that the beam is around 12×12. That is the plan that I have is to use screw jacks moving the house a little at a time prob. within a couple weeks, then going in to cut out the beam. The olny advantage I have is the floor has to be replaced anyway so I can romove that first and work from there. Hope it helps, good luck. Mike M.
  1. Mike_M._Va | Oct 05, 2000 04:52am | #1
    Tim, I just quoted the same job ona house built in the 1800's, with the exception that the beam is around 12x12. That is the plan that I have is to use screw jacks moving the house a little at a time prob. within a couple weeks, then going in to cut out the beam. The olny advantage I have is the floor has to be replaced anyway so I can romove that first and work from there. Hope it helps, good luck. Mike M.
  2. Guest_ | Oct 05, 2000 05:56am | #2
    Tim,
    I just replaced a section of the sill on my own house a few months ago. It also has a crawl space. I used a 6"x6"x12' railroad tie and a few bottle jacks. You don't have to lift up very much ; just take the weight off the sill. Get a bunch of 12" sawzall blades and a cats-paw nail puller. Carve out the old sill and add in a new pressure teated one same height. Not very hard, just awkward getting the RR-tie under there. Go slow and don't lift very much at all.
    1. Guest_ | Oct 05, 2000 12:56pm | #3
      *Thanks for the advice. It doesn't seem like it will be all that bad of a job. Lucky for me I am getting paid by the hour! I'll let you know what happens in a couple of weeks. Thanks again.
      1. Guest_ | Oct 05, 2000 02:24pm | #4
        *Tim,It really helps if you have a complete understanding of how your project is framed. Do you know the construction date? Houses with sills that size can be either post and beam or early balloon framing. How you approach each is different. Both have their difficulties and advantages when it comes to sill replacement. If you know more, I can elaborate.Steve
        1. Guest_ | Oct 06, 2000 02:52am | #6
          *Steve, I do not know the date the house was built. I belive that it is post and beam. The strange thing is this is a gable wall. The second floor joists are parallel to the sill to be replaced. However, there was a beam installed about 8' from the sill running parallel with it. The first floor joists are perpendicular running from this beam and resting on the sill. I can not make sence of this practice. It seems like it could be original.
  3. Guest_ | Oct 06, 2000 02:52am | #5
    I am working on an older house. I uncovered a rotten sill when I was looking at sagging floor joists. The current sill seems to be a 6.5"x6.5" beam. The other problem is that I will be working in a crawl space. I thought about trying to replace it from the outside but there is a set of concrete steps in the way. What I would like to find out is if I can just cut out the rotten part and replace it with a treated beam. If so then should I just jack up the floor from the inside and try to replace the sill. Any advice would be greatly appreciated.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
