Router bit for creating h/w floor groove
RustyNail | Posted in General Discussion on April 5, 2002 04:45am
Does anybody know where to get the 1/4″ top bearing bit used for creating the groove for hardwood flooring tongues (mentioned in the Jan ’02 issue of FHB)?  (FYI, it’s standard 3/4 red oak flooring I’m dealing with).
Also… wouldn’t I get the same effect by using a router table and a 1/4″ 3-wing slot cutter set to the proper height and depth of cut?  While the stock wouldn’t be riding on the bearing for the slot cutter, the table would maintain the proper depth of cut.  Is this a good approach?
  1. bill_1010 | Apr 05, 2002 05:35pm | #1
    This was asked before. The author(i think) came here and said where he got the bit, as per fhb jan 02.  I htink it was MLSC bits. The post was in the old forums, dont know if that (post) made it over.
    OK did a quick search look here. they spill the beans on the bit
    http://forums.taunton.com/n/find/findRedir.asp?webtag=tp-breaktime&mg=A74CA7B9-E28F-419B-AB08-41A349DA8656
    Edited 4/5/2002 10:36:56 AM ET by BILL_1010
    Edited 4/5/2002 10:38:30 AM ET by BILL_1010
    1. RustyNail | Apr 05, 2002 07:15pm | #2
      Thank you much!  I usually do a search before posting, but with the new format...  I guess I was reluctant to dig through the old posts.
      Thanks again!
        JeffBuck | Apr 06, 2002 08:56am | #3
        Don't know how much ya have to do.....but a few passes on the table saw is how I've done it in the past. Jeff   *  Jeff J. Buck/ Buck Construction/ Pittsburgh, PA  *
        2nd Generation Buck Const, 3rd generation Craftsman
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
