Router template material
fingers | Posted in Construction Techniques on January 9, 2007 02:17am
What do you like to use for router template material?  I’ve got to make a lot of architectural brackets for a Victorian and was going to make them out of azek.
Because there’s quite a few and I want them all uniform, I’m going to spend some time and make up all the templates.  Luan? Hardboard? Baltic birch?  What’s your preference?  Thanks.
  1. Stilletto | Jan 09, 2007 02:19am | #1
    MDF it's free of voids.
  2. CAGIV | Jan 09, 2007 02:38am | #2
    depends on what type of bit you are going to use.  If it were a flush trim bit I'd use hardboard because it's thinner, durable, and easy to work with, if you're going to use a bushing as a guide I'd probably use 1/2" MDF....
    If you have Azek laying around I don't see any reason why it wouldn't work.
    Team Logo
  3. jackplane | Jan 09, 2007 04:04am | #3
    yep, mdf
    Expert since 10 am.
  4. DougU | Jan 09, 2007 04:22am | #4
    MDF
  5. ponytl | Jan 09, 2007 04:30am | #5
    I've had good luck with lexan... 1/4"   all mine was old sign faces... find where the sign shops are and most have a dumpster full of it...
    p
  6. nailbanger | Jan 09, 2007 05:47am | #6
    Lexan, I can sometimes get scraps, from my glass guy, that are big enough to use for templates, sometimes I buy it. I like being able to see through it when I'm lining it up.
    BILL
  7. MikeSmith | Jan 09, 2007 06:25am | #7
    i've got alot of 1/4" lexan scraps.... cool  with the transparency
  8. User avater
    zak | Jan 09, 2007 06:34am | #8
    1/4" frosted plexiglass.  We've got tons of little chunks around the shop, the frosted is easy to draw or write on, and it machines easily.
    zak
    "When we build, let us think that we build forever.  Let it not be for present delight nor for present use alone." --John Ruskin
    "so it goes"
  9. plumbbill | Jan 09, 2007 07:10am | #9
    Not much for templates, but I need different base plates for things. I use those white nylon cutting boards to hold my routers.
    Works great & doesn't scratch the finish surfaces.
    “How many observe Christ’s birthday! How few, his precepts! O! ‘tis easier to keep Holidays than Commandments.” —Benjamin Franklin
  10. IdahoDon | Jan 09, 2007 07:12am | #10
    I like hardboard or mdf.
