Routing wiring through rigid insulation
denovo | Posted in Construction Techniques on November 10, 2008 08:57am
I invite recommendations for routing the wiring for lights and ceiling fans up through 2×6 t&g exposed roof decking and into the rigid insulations panels.  I envision somethhing like routing a channel with a hand held and possibly battery operated router.
Thanks for any tips
  1. Dan612 | Nov 10, 2008 09:34pm | #1
    I read once somewhere about a way to put a chase through rigid foam.  The author was describing a way that if you stand the panel up on edge, plumb it to make sure it is perfectly vertical, and then heat a steel ball bearing up until it is red hot, and drop it on top of the panel.  He claimed it would burn it's way through the panel in a nice, straight line.  I have NEVER tried this, due to the smole from burning rigid insulation is nothing to joke about. (polyiso foam burning makes something similar to nerve gas).
    With that said, I think a router bit may get hot enough to make the stuff smoke too.  I also would check if you can run wires with no clearance against foam.  I have had good luck cutting the stuff with an old hand saw.
    1. DickRussell | Nov 10, 2008 09:49pm | #2
      "...and then heat a steel ball bearing up until it is red hot, and drop it on top of the panel."I saw that on TV, on the Green building channel. They were building a house with SIPs and had to run a hole not among those from the factory. They heated the ball with a torch and dropped it on the top edge. After a minute or so, it plopped out the bottom edge.
      1. Dan612 | Nov 10, 2008 10:04pm | #3
        I have seen a lot of things on TV. . . It still doesn't mean I am going to try it.  I am a little suprised that burning styrofoam made it onto the "green building" channel.
  • Drafting the 2027 IRC
  • Get a Grip
  • Wire- and Finger-Safe Cable Stripper
  • Two Ways to Test Windows
