Sanded grout application technique?
| Posted in General Discussion on February 1, 2001 07:44am
I’m using a lot of Talavera tile in my house. It’s the old style handmade tile from Mexico – very uneven stuff and very thick. Traditionally the grout lines in Talavera are very wide; it’s a good thing, too, because the tiles are so irregular in shape that I have to compensate with varying grout line widths. I have not been able to float the grout like I have on other 4″ field tiles. The Talavera tiles are so thick and each one is either convex or concave. When I try to float the grout I have to put 1/4″ to 1/2″ of grout over the entire surface of the tiles to clear the high spots, and then try to get those huge grout lines full. Grout goes everywhere but where it’s supposed to be.
So I end up hand filling the grout lines one at a time. It is tedious but I don’t really mind it – at least I get the grout in good and full and solid. I tried using plastic gloves but I couldn’t work with them on because I couldn’t feel what I was doing. But without them I sanded the skin right off my fingertips. How do professionals solve this? (Short of using red grout, of course.)
Also, I’ll be using 4″ x 12″ bullnose saltillo tiles (stained to match existing brick floors) instead of wooden baseboards in rooms where we had walnut colored laminate flooring laid. (I know, gag, gag.) I plan to use mastic to glue the bullnose to the wall, use the same sanded grout for these grout lines that I’m using in the bathrooms, and use sanded colored caulk where the tile meets the floor. Sound right? Or should I just sit the tile onto the laminate and put a little bead of clear caulk along the bottom to seal the crack? Or something else entirely?
Thank you.
  1. Lisa_Long | Feb 01, 2001 07:44pm | #1
    I'm using a lot of Talavera tile in my house. It's the old style handmade tile from Mexico - very uneven stuff and very thick. Traditionally the grout lines in Talavera are very wide; it's a good thing, too, because the tiles are so irregular in shape that I have to compensate with varying grout line widths. I have not been able to float the grout like I have on other 4" field tiles. The Talavera tiles are so thick and each one is either convex or concave. When I try to float the grout I have to put 1/4" to 1/2" of grout over the entire surface of the tiles to clear the high spots, and then try to get those huge grout lines full. Grout goes everywhere but where it's supposed to be.
    So I end up hand filling the grout lines one at a time. It is tedious but I don't really mind it - at least I get the grout in good and full and solid. I tried using plastic gloves but I couldn't work with them on because I couldn't feel what I was doing. But without them I sanded the skin right off my fingertips. How do professionals solve this? (Short of using red grout, of course.)
    Also, I'll be using 4" x 12" bullnose saltillo tiles (stained to match existing brick floors) instead of wooden baseboards in rooms where we had walnut colored laminate flooring laid. (I know, gag, gag.) I plan to use mastic to glue the bullnose to the wall, use the same sanded grout for these grout lines that I'm using in the bathrooms, and use sanded colored caulk where the tile meets the floor. Sound right? Or should I just sit the tile onto the laminate and put a little bead of clear caulk along the bottom to seal the crack? Or something else entirely?
    Thank you.
Fine Homebuilding – July 2023, Issue #316
Find online articles on timber-framed solar canopies; the right footings; the best toilets; choosing insulation; compact cordless routers; and much more.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
