Sander for Wet Use
| Posted in Tools for Home Building on February 12, 2004 03:50am
I am looking for a portable disc sander that I can use to help remove a finish from a concrete kitchen countertop.  (I’ve done it before, so I know it can be done.)  I will be using water as a lubricant, so the process will be messy.  When I did it the last time, I used my trusty Porter-Cable random orbital palm sander, but that was a smaller area.  My concern (frankly, I didn’t think about it then) is insulation — obviously one is generally hesitant to use power tools around water.
I don’t need a heavy duty “water sander” that connects to a hose and constantly feeds water.  Is there any reason I can’t use a good Makita, Hitachi, PC, Milwaukee or Bosch disc sander and just keep it away from water? Maybe wrap a rag around the motor to avoid splashing? Or will that cause the motor to overheat?
    Sphere | Feb 12, 2004 03:59am | #1
    you CAN do that..but a better way is a cheap RO air powered sander..Harbor Freight has em..6" for about 50 bucks IIRC..any auto body type place has em too..I like the SOUIX (SP?) 5'' ..
    1. bnute | Feb 12, 2004 05:21am | #2
      USE A VARIABLE SPEED GRINDER TURNED ON LOW WITH DIAMOND DISCS.  A SPONGE SATURATED WITH WATER THAT IS SQUEEZED OCCASIONALLY WILL GIVE YOU ENOUGH WATER TO LUBRICATE THE DISCS.  THIS WILL SPEED THE JOB UP CONSIDERABLY.  MAKE SURE YOU PLUG INTO A GFCI AND YOU'LL BE FINE
  2. FastEddie1 | Feb 12, 2004 06:57am | #3
    Isn't the cord on the PC a two-prong?  That means it's double insulated, and the case is plastic too.  Plug into a GFI and have at it.
    Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
    The craftsman formerly known as elCid
A New Approach to Foundations
