Sanitary vent pipes
| Posted in General Discussion on April 7, 2005 04:44am
I have a sanitary vent pipe on the roof that is white PVC cut straight across. It freezes up in the winter causing a backup of odor in the basement. I live in northern Wisconsin where it gets really cold. Could painting the PVC black or cutting the opening on a angle resolve the problem. Its tricky climbing on the roof with a foot of snow on it to clear the vent pipe.
  1. cliffy | Apr 07, 2005 05:08am | #1
    Vent pipes should only have air, or is snow blowing in there and freezing in place.  I'm in a snowy area with long winters with R60 attic insulation so when I plumbed my house I ran the 3 inch vents about 2 feet over the roof so the end would stay above the snow.  Worked so far.
    Have a good day
    Cliffy
    rjw | Apr 07, 2005 05:30am | #2
    The only cure I know is to go to a bigger vent.
    They can frost up in cold weather as the moisture in the gases rising from them freeze at roof level and build up inside the vent.
    I see it frequently in my area when the weather drops below 10 -15 degrees or so. (Have some pics, but couldn'yt find them.)
    Sojourners: Christians for Justice and Peace
  3. Tyr | Apr 07, 2005 05:55am | #3
    PVC?  White?  Doesn't that break down exposed to UV from the sun?
    Odor in the basement?  Sounds more like a dried out trap.  Any floor drains (say a laundry room floor) that don't naturally get the water level replenished?  Any "preplumbed" bathrooms in the basement?  Maybe a drain in the concrete floor?  Again, it dries out.  Take some of Lake Superior and pour it in those dry traps every few months.  I make vent pipes longer too.  I can 't imagine outside moisture (snow)  freezing up the vent but could a fitting with a 180 degree turn attached to the vent pipe work.  Heat tape?  Insulation?    Tyr
