This ought to do ya…
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
Pump jacks would be the way to go.
ANDYSZ2
I MAY DISAGREE WITH WHAT YOUR SAYING BUT I WILL DEFEND TO THE DEATH YOUR RIGHT TO SAY IT.
Remodeler/Punchout
You're planning on replacing the siding on the gable wall, too, I assume?
I'd scaffold it up full height by full width. You don't have much overhang so that's a blessing.
You're gonna need half-width frames to fit in the width of your stairs, and half-height sections to step up the stairs until you get to the top. I hate those 29"-wide frames because they're so narrow they wobble if you even look at them...but you're gonna have to tie the whole thing onto the house no matter what, so it should be okay.
Dinosaur
A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
But it is not this day.
thanks for the replies
Well, you know, I live in a dairy farm area. Should be cheap on supplies. :)
Thats good, but I would have left the bales on the trailer. That way you could pull your setup around th the rest of the house. Great picture Ralph, made my day.
What about a ladder jack setup with scaffolding??
-m2akita
Anything other than pump jacks is going to be very restrictive for siding work. I don't think you can set ladders up on the stair side and I own a bunch of the narrow scaffolding and it would be a huge pain in the butt to set up that much scaffolding to cover that long a run.
You should be able to rent the pump jacks but there not that expensive to buy, the long walkboard needed is rather expensive but I would definatel;y use a long alum. walkboard.
Remodeler/Punchout
Set up some layered - one time - do the job.
Thanks. Need something less spendy.
Is that job done yet Ralph?
All done. Money's in the bank.
That's the best kind of job.
rent a snokle lift
Damn you, put a warning on those things! I just shot a mouthful of coffee through my nose. Smells nice, though.
-duke
DCG Your Neighbor's Contractor LLC
"A wrongdoer is often a man who has left something undone, not always one who has done something."--Marcus Aurelius
HAHAHA Ralf, loved the redneck scaffold!!
I would rent a bucket lift......probly only need it a couple days, so it wouldn't be that much. Lot less work than the 29'' scaffold
WARNING: Contents may cause unexpected ejection of caffine-laden beverages through abnormal passages in the naso-pharyngal complex. Wear full coffee nose protection before scrolling down to view the following. Failure to follow these safety instructions may result in serious injury or death or brown stains on the front of your teeshirt.
Dinosaur
LIVESTRONG
http://www.hay98.com/
Edited 8/28/2005 7:54 pm ET by Gunner
Dinosaur
