Screwing into Soapstone
MikeK | Posted in General Discussion on July 16, 2006 05:31am
I just had soapstone countertops install. The contractor was afraid to screw the top of the dishwasher into the bottom of the soapstone, for fear or cracking it.
Has anyone installed soapstone? How do screw into it. Pilot hole?
Thanks.
    jagwah | Jul 16, 2006 05:52am | #1
    Just an idea.... why not carefully drill a hole twice the diameter of your screw and slightly deeper than it will go in. Apply bondo to the hole and let it set up well. Now tape and put in your screw. This way there is no stress  put to the top.
  2. calvin | Jul 16, 2006 06:10am | #2
    Get a couple of very short (wafer head if possible) stove bolts.  Epoxy the matching nuts to the bottom of the counter where the mounting tabs are for the dishwasher.  Once the epoxy sets, screw the DW to the nuts.
    OR, if a new DW, read the instructions closely, many have side-cabinet mounting option.
    Quittin' Time
    1. DonCanDo | Jul 16, 2006 06:29am | #3
      I'm not sure how long the epoxy would hold up so close to the heat and steam from the dishwasher.
      A threaded brass insert might be the way to go.  Although, it would have to be epoxied into the hole also, the epoxy wouldn't be directly exposed to heat.
      -Don
  3. andybuildz | Jul 16, 2006 12:00pm | #4
    http://www.soapstones.com is their site... Teixeira is the name of the company I used for my slabs . Great people there! Give em' a shout.
    Step 6: Mounting the Under mount Sink to The Countertop
    We recommend drilling slots on the bottom of the stone on the 4 corners of the sink cut out. You will drill a slot that can accommodate a screw head in the stone, so you can attach your clips to secure the sink to the stone. You will also run a bead of silicone along the edge where the sink is in contact with the stone.
    If there is anything we did not cover here, we do offer live support on our toll free line 877.478.8170.
    If Blodgett and Gunner say, Tipi tipi tipi it must be so!
    TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
    Edited 7/16/2006 5:02 am ET by andybuildz
  4. SHG | Jul 16, 2006 12:15pm | #5
    See Andy's post.  I've drilled holes into the bottom as well with no problem at all.  That's the beauty of soapstone.  Think of it like you're working with wood.
A Practical Perfect Wall
  • The New Old Colonial
