Scrooge clamp
| Posted in Tools for Home Building on March 11, 2006 09:16am
How would these work in framing, for straightening and lining wallframes?
$29.50 each from Lee Valley.  You supply the 2x4s.
    Huck | Mar 11, 2006 09:49pm | #1
    Sure, it would work.  We used to use a bigger, steel model for larger commercial projects.  On residential framing, jacking and bracing is readily accomplished using framing lumber on hand.
    "he...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
  2. MikeSmith | Mar 12, 2006 12:30am | #2
    depends on the throw of the thread.. if it's fine then they would be useless.. if it's exceedingly coarse,  and the total adjustment is in the 6" range, then they'd  work............  ok..
     they are not as versatile as concrete-form adjusters because they are harder to mount...   the ones we use, have angled mounting plates and big holes to drive rebar thru and little holes to drive nails thru
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
