Sealed Comb. LP H20 Heaters for Radiant
AKHandyman54 | Posted in General Discussion on January 12, 2005 04:21am
I am looking for a dealer or manufacturer who makes efficient LP Hot water heaters that are sealed combustion, direct vented for duty as both a domestic hot water heater and to provide hot water for approximately 1850 sq. ft. of radiant floor heating. Anyone care to help?
    johnnyd | Jan 17, 2005 06:24pm | #1
    Bradford White makes one called combi-cor
    http://www.bradfordwhite.com/products.asp?category=Residential_Hydronic/Space_Heating/Storage_Tank/Indirect-Fired
    Although you might be better off with a traditional water heater, provided it is sized correctly to meet your heating load, rated for space heating, and uses a heat exchanger to separate the domestic side from the heating side.
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
