Securing Retrofit Post In Concrete
JasonQ | Posted in Construction Techniques on October 16, 2007 04:43am
Got this porch.  I have columns, but need to place a couple of intermediate and end posts.  My thought was to drill & set bolts w/ epoxy, use Simpson 6×6 post bases to set the posts, then put up my railings.  Do y’all think that will work and be strong enough?
Jason
  1. JasonQ | Oct 18, 2007 06:00am | #1
    Anyone...?  Anyone...?  Bueller?
  2. grpphoto | Oct 18, 2007 06:34am | #2
    Well, how do you intend to attach your posts? If appearance is not an issue, I usually use some sort of metal bracket attached with an expandable screw anchor (similar to "red-heads").
    George Patterson
  3. Ragnar17 | Oct 18, 2007 07:09am | #3
    Will the posts be supported at the top end as well as the base?  Or will they be like a newel post and supported at the bottom only?
