All,
I run into a problem in a commercial building securing some pine trim to the drywall to look like wainscoting. I though there would be metal studs behind the 3/4″ drywall and I could use screws to hold the trim fast to the wall. But everyplace I tried there seems to be solid block behind the drywall. I don’t think brad nails will hold in the drywall so I was wondering if anyone else ran into this situation and what did you use to secure the trim?
Rocky
You might try using some PL Premium or some other construction adhesive, and then shoot finish nails at oposing angels to secure the wood while the glue sets up.
One thought
I've used that new Loctite Power Grab, works very well and does have a real strong initial set. Good luck!
Paul,
Sounds like a good solution, I'll give it a try!
Rocky
Rocky....if you could be a bit more specific, it might help us envision what exactly you`re trying to do. Are you attempting a raised panel look? How thich is the pine stock?
Construction adhesive would certainly be a suggestion, but it won`t be enough to secure it properly. I`ve used cut nails with success. Masonry nails....even screws depending upon the application.
If you can prefab the wainscotting rather than building in place, less fasteners will be required to attach it to the walls.
But again, without more details, its kinda hard to give the proper advice.
ATTENTION FELLOW BREAKTIME MEMBERS:
If you`d like to discuss topics other than home building, come on down to the Woodshed Tavern. Great bunch of guys and gals letting off a little steam about everything and anything. Its not a special club, but.....as of Monday, March 14, the Tavern folder will go behind an access wall. Only those who request access to this folder by contacting [email protected] will be able to view and participate in discussions there.
I had a similar situation a while back. I fastened plywood (at least half inch) over the drywall/metal studs, then nailed into that. You will need to make provision on your top rail for the extra space, but that worked better for me than the glue and pray method.
