Security systems
TomMGTC | Posted in General Discussion on April 18, 2006 03:31am
Can anyone recommend a good DIY security system.
Hardwired is preferable. Not a big house but it is far away. I want to be able to have it call me, not a monitering center, and I want the capability of having a temp sensor for freeze. Would like to be able to arm disarm remotely as well.
There are so many systems out there that I don’t know where to begin.
Tom
Douglasville, GA
  1. mcf | Apr 18, 2006 03:57pm | #1
    check out either
    http://www.basshome.com
    http://www.smarthomeusa.com
    1. TomMGTC | Apr 18, 2006 08:23pm | #2
      I've seen the websites and that is part of the problem. They have so much information and eqipment available that it is hard to sift through it all. I was hoping for some first hand experience with some of the systems.
       Tom
      Douglasville, GA
      1. mrsludge | Apr 18, 2006 11:23pm | #4
        I highly recommend the forum at homesecuritystore.com.  I also don't suggest using basshome.com after a bad experience (received incomplete order w/ some items not as ordered; zero luck at contacting via e-mail, phone, or fax; disputed credit card charge and returned partial order to distributor; received remainder of order a few weeks later from another distributor w/ no way to return).  Think that guy must just use Usenet and doesn't actually run his business.
        I updated an older Ademco system w/ new zones for an addition, and it wasn't too hard.  A newer system might get you all the flexibility you need.  Have also played a bit w/ Napco Gemini system at FIL's house- it has amazing flexibility, but I suspect it might be difficult to DIY program.
    skip555 | Apr 18, 2006 08:28pm | #3
    you might want to try a post here
    http://forum.doityourself.com/forumdisplay.php?f=87
