In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Serious water hammering
| Posted in General Discussion on February 5, 2004 04:07am
We recently bought our first house and it is great..except for the water hammering when running hot water.  Most noticable in kitchen and bath sinks.  Standard 3/4″ piping is buried in the walls with the valve protruding into the cabinet opening.  3/8″ flexible copper tubing runs from the valve to the sink.  What options do I have to stop the water hammering?  Will the commercial 3/4″ water hammer suppressors work if I splice into the 3/8″ line using couplers?
LASteve
  1. Sungod | Feb 05, 2004 04:19am | #1
    The lousy plumber did not secure the waterlines in the wall.  Also see if the water pressure too high.
  2. DanH | Feb 05, 2004 04:52am | #2
    There are several varieties (different connectors) of water hammer suppressors you can install. Best would be to "dismount" the current shutoff valve (I'm betting it's 1/2", not 3/4"), install a suppressor on a tee, then the valve. This gives full flow into the suppressor. Depending on how the valve is attached (generally either threaded to a soldered-on brass coupling or attached with ferrule and compression nut) you would need a different tee (suppressor with integrated tee).
    Also, anchor any accessible parts of the problem pipes.
    BillHartmann | Feb 05, 2004 05:21am | #3
    There is different kinds of water hammer.
    If you have a single bang followed by several rattles when the water is shutoff the hammer arrestors will help. This is caused by the water suddenly being stopped and no place for the momentum of the water to go.
    If you a continous series of bangs rattles, whistles, screaming, etc was long as the water is flowing it is a different problem. There is something loose that is causing this. The most common problem is with a loose washer and that is caused by a loose/missing screw or the wrong size washer. It can also be cause by something in the pipe moving or by worn stems.
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
