Service Entrance Cable
Paladin51 | Posted in General Discussion on September 19, 2008 07:52am
Preparing to wire my new shop & I am getting conflicting advice on my service entrance Cable.
I am installing a 100 Amp Sub Panel. Main panel is 270′ feet away.
It is a one-man shop so it is unlikely I will ever use 100 Amps at one time but I do want to do it properly.
I have been told & found on-line recommendations from #4 Aluminum to 2/0 Copper. What do you gentlemen think?
And why does every panel require it’s own ground? If I use a 4-conductor cable & ground the sub-panel & run a ground back to the main panel doesn’t that create a “ground loop”?
Thanks everyone….
  1. gfretwell | Sep 19, 2008 09:25pm | #1
    Minimum code would be #3 copper or #1 aluminum. (310.16)
    Ground loops are not an issue on power wiring. In fact we make them all the time. You establish a local ground electrode system at each building to be sure your electrical ground is at the same potential as the concrete floor you are sitting on. Earth is seldom actually "ground" in the "zero volts" sense. The more bonding/grounding you have the less "stray voltage" is a problem.
    1. Paladin51 | Sep 19, 2008 10:00pm | #2
      Thanks...
      BillHartmann | Sep 19, 2008 10:06pm | #3
      Did you account for volt drop?I get 1/0 or 3/0..
  2. RustyNail | Sep 19, 2008 10:40pm | #4
    I agree w/ Bill on this.  #3 Cu would work if you were closer to the main panel.  However, at 270', it would have too large a voltage drop if you're pulling decent current.
    1. gfretwell | Sep 20, 2008 05:56am | #5
      I agree with the statement in the original post. It would be hard to pull anything near 100a in a one man shop.
        BillHartmann | Sep 20, 2008 06:38am | #6
        You are right if it only wood working shop.I am not sure, but I think that some welding stuff get up near there..
Two Ways to Test Windows
  • The New Old Colonial
