setting posts
Ryan1 | Posted in General Discussion on April 8, 2005 07:17am
I’m just a DIY’er, but I was hoping that one of you pros could point me in the right direction.  This weekend I will begin building a swingset/playhouse out of PT lumber and need some advice on setting the six 4×4 posts that will support the playhouse portion and one side of a 4×6 beam for the swings, etc.  (the other end of said beam will be supported by a simple “A”)
To get the posts square should I just use the 3, 4, 5 triangle rule with batterboards and mason’s cord?  Or am I overlooking the obvious?
Any ideas would be appreciated.
  1. YesMaam27577 | Apr 08, 2005 11:09pm | #1
    The 3-4-5 method is a good one, but you'll need to remember what surface or what corner of the third post is being laid out.
    Depending on the size of the rectangle, another method for a DIYer is to put a couple of sheets of plywood on the ground, using them as the square layout tool. You could also scap together some 2X4's, with a diagonal brace, letting the resulting rectangle be the layout tool.
    And don't spend the entire day getting it right to the width of a gnats eyelash. If you're within 1/8, the world will still rotate.
    Unless you're the lead dog, the view just never changes.
    1. Ryan1 | Apr 08, 2005 11:35pm | #2
      Thanks for the help.
Podcast Episode 695: Saving Bricks, Cut-and-Cobble Insulation, and Waterproofing Foundations
Listeners write in about paint strippers, bricks, and FHB Podcast volume and ask questions about insulating under membrane roofs and whether waterproofing prevents concrete foundations from drying.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
