In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Sewer Gas Smell
BradEcho | Posted in General Discussion on October 27, 2008 09:58am
I have a two story house built in 1914. It has a bathroom on each floor right above the other using a shared stack pipe / vent (our only vent pipe). In the basement we have a bell floor drain that I keep vegetable oil in.
Periodically when the second floor toilet is flushed, we get a sewer smell both in the downstairs bathroom and in the basement.
A few years ago, we found that a section of our stack pipe was cracked and had our plumber replace it.
Are there any cleaners would anyone recommend for putting down the drains? Down the main stack? Maintenance that I could do that would help eliminate the problem?
I’m thinking our lone vent is a big problem. Would the installation of an AAV help?
  1. DanH | Oct 27, 2008 10:08pm | #1
    Odds are you've got another crack. Though it might be worthwhile to try replacing the wax rings under the toilets.
    Corporation: n. An ingenious device for obtaining individual profit without individual responsibility. --Ambrose Bierce
    1. BradEcho | Oct 27, 2008 10:37pm | #2
      If one of the wax rings was the problem wouldn't it also be leaking? We rarely experience the smell on the second floor (exception is when the HVAC unit is running).
      1. DanH | Oct 27, 2008 10:48pm | #3
        Nope. You can have a gas leak without a (serious) water leak.
  2. Eldan | Oct 27, 2008 10:54pm | #4
    Is the first floor sink or tub rarely used? Maybe the trap water level has evaporated to the point where a bit of vacuum caused by the flush breaks the seals. Run the water for a while in the first floor fixtures and add some more water and oil to the basement drain and try flushing again.
    1. BradEcho | Oct 27, 2008 11:42pm | #5
      The first floor bathroom is used all the time. The second floor sink and toilet are used daily. The second floor clawfoot tub is rarely used.
      1. Eldan | Oct 28, 2008 12:38am | #6
        I think you'll have to take the upstairs bath off the original vent stack and run a separate one. That's code, anyway.
        1. DaveRicheson | Oct 28, 2008 06:47pm | #7
          That depends on vent stack size and fixture count.
          1. Eldan | Oct 28, 2008 09:06pm | #8
            1. Toilet cannot be the the upper fixture on a wet vent.
            2. No toilets on waste stack.
            I think the OP needs to at a minimum run a new drain from the 2nd floor toilet and tie it in to the basement after the floor drain fixture to prevent siphoning out his traps every time he flushes. And the toilet would work better if the new stack is vented or tied in to the main one in the attic.
          2. splintergroupie | Oct 28, 2008 09:24pm | #9
            The house was built in 1914. Plumbing may or may not have been done then, but newer code does not require a re-plumb of all old houses. I had the same configuration as the OP in my Victorian with two toilets on the wet vent and it all worked just dandy with no sewer odors. I also vote for checking out cracked pipe and/or snaking the vent, considering that's already been a problem.
          3. Eldan | Oct 28, 2008 09:52pm | #10
            It's worth a shot. OP, let us know how it works out!
  3. rv10 | Oct 29, 2008 03:24am | #11
    For what it is worth is there any pvc tub or shower drains ?
    These tend to develop a sewer gas smell if not cleaned regularly.
    (fungus seems to attach to pvc but not copper or brass.)
    If pvc try bleach and rinse.
    Jeff_Clarke | Oct 29, 2008 09:00am | #12
    Is there a washing machine anywhere on this stack potentially causing problems with sudsing?
Cleaner Tile Demo
Cardboard boxes lined up with a tiled wall makes demo cleanup quicker and easier.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Track Lighting for Functional Ambiance in Busy Spaces
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
