Has anybody ever seen or installed Asbestos sewer pipe. I just found it outside my newly purchased home that i am remodeling. Do they make couplings or ferncos to hook up PVC to it. The old cast was leaded into it.
There also seems to be a trap installed in the line close to the road. Is this possible, i have never seen a trap installed in a sewer line.
Greetings spike,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
94969.19 In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
It is a grease trap?
Tu stultus es
Also a CRX fanatic!
Look, just send me to my drawer. This whole talking-to-you thing is like double punishment.
Yes they do make Ferncos for pvc to asbestos. That trap is a whole house trap, some jurisdictions still require them. If you have to cut the asbestos pipe make sure you don't breath the dust, luck.
I have never seen asbestos sewer pipe myself, but from my experience, there will be a Fernco type adapter to fit your needs. You may need to hunt down a good plumbers supply, and you may have to order it.
The main concern is that the inside of the sewer maintains a smooth internal waterway, (no where for things to snag).
>>>"There also seems to be a trap installed in the line close to the road"<<<
Are you sure that isn't just a 'Cleanout'? This would make more sense.
"House traps" are typically located close to the house, and have a mushroom type cap on the vent.
I hope this helps!
Thanks guys, i did find a Fernco adapter. It is a trap, has the mushroom cap on it. The cleanout is about 4 feet in front of it
I replaced my old clay tile that was full of tree roots a few years ago, and the county wanted a cast iron trap with vent (mushroom cap) near the house, and a separate cleanout further out.
Ran 4" schedule 30 into the 6" a ways where the clay was still good and mortared around it . Passed inspection. Replaced old galv. supply line with 3/4 copper while it was open, too.
Bear
