Sheetrock with obsticals
bigstax | Posted in Construction Techniques on May 14, 2013 11:36am
   I am sheetrocking my basement ceiling and i am ready to put up the last piece. In the one corner of where the piece will go, there is a joist hanger that hangs down 1/8 inch. this is where the rock will butt the existing piece. Wondering if I should cut out around it and have taper just go over it? Or should I just cut out back of piece to be installed an 1/8th in. ? Or is there a better way? Thanks.
  1. florida | May 14, 2013 02:55pm | #1
    Cut the drywall and let the taper fix it. No big deal at all.
  2. DonCanDo | May 15, 2013 07:07am | #2
    Shave the back
    I would "mortise" the back of the drywall to accomodate the joist hanger. A wide chisel works well..1/8" won't reduce its strength significantly.
    Shaving the back will be faster than dealing with a taper.
  3. cussnu2 | May 15, 2013 04:09pm | #3
    If you go look hard enough, I'm sure there is a new tool you need to complete the job.....
    hey women have to have a new pair of shoes to go with a new outfit when they already have a couple of dozen pairs.
Scaled to Suit the Site
This thoughtfully designed home preserves the character of its neighborhood while maximizing space for a growing family through careful attention to scale, rooflines, and material choices.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
