We are building out and addition, and one partition wall has some studs which are uneven as measured horizontally with an 8′ straight edge (a level on edge) at a few elevations. The wall will be half tile over mortar board and half 3/4″ tounge and groove. Some of the areas are out of straightness (left to right, not up and down)by as much as 1/4″. Two questions:
1. What is proper tolerance for this application? I can feather out the mortarboard, and the 3/4″ stock will be fairly stiff as well. I assume about an 1/8″ or less is OK.
2. In shimming, which is better, planing out the high spots with a cheap hand planer (being carefull not to hit nails) or ripping some thin shims and tacking them in place?
Thanks in advance.
We are building out and addition, and one partition wall has some studs which are uneven as measured horizontally with an 8' straight edge (a level on edge) at a few elevations. The wall will be half tile over mortar board and half 3/4" tounge and groove. Some of the areas are out of straightness (left to right, not up and down)by as much as 1/4". Two questions:
1. What is proper tolerance for this application? I can feather out the mortarboard, and the 3/4" stock will be fairly stiff as well. I assume about an 1/8" or less is OK.
Thanks in advance.
