Shluter Ditra loose tiles?
Crash | Posted in Construction Techniques on September 30, 2005 01:21am
Hi folks,
I used Shluter Ditra for the first time in my own bathroom and family room additions.  The family room is working out just fine.  However, after a couple of years I have some floor tiles in the bathroom that are coming loose.
The bathroom floor is 2×12 joists, 16″ on center, with 3/4″ plywood subfloor (same as family room).  The joist span 16 ft in the bathroom whereas the joist span 12 ft in the family room (3 spans of 12 ft for a total of 36 ft).  I suspect that maybe there’s a little bit of bounce in the bathroom due to the 16 ft length of the joist and it’s just enough to make the loose over time.
Anyone have any other thoughts?
Thanks in advance,
Roger
  1. wane | Sep 30, 2005 03:37pm | #1
    I'ld expect tiles to crack if the floor was bouncey, loose tiles are usually the mastic failing or improperly applied , at least you should be able to remove and replace them ..
  2. andybuildz | Sep 30, 2005 03:45pm | #2
    Even though it takes longer I "always" backbutter my tiles in all situations. Its that added insurance that just makes me feel all warm and fuzzy inside.
    Also, you may consider next  time if possible to add another 1/2" on top of the 3/4". Its always better, not that I always do it.
    Be well
    andy
  3. timkline | Sep 30, 2005 04:05pm | #3
    probably the thinset was too dry and you didn't get good bonding.
    it is unlikely that the floor flex has much to do with this.
    carpenter in transition
      Dinosaur | Sep 30, 2005 05:03pm | #4
      Hey, Rog--
      When working with Ditra, sometimes it happens that one doesn't get all the air bubbles out from under it, and this can cause failure later on. The only way to find out is to pop the loose tiles out completely. Then you'll see if it was the tile that unbonded from the membrane, or the membrane which unbonded from the substrate.
      If the Ditra came unstuck from the floor, you cut an X slit into it, scrape the dried thinset off the substrate, and squirt or squiggle some new thinset in under the membrane. Then you slide a patch of membrane in under the X so it laps under the edges of the slit area, trowel in more thinset on top of the patch, making sure you get some between the patch and the original layer of membrane where they overlap, and finally reset the tile(s) on top.
      Dinosaur
      A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
      But it is not this day.
        Crash | Sep 30, 2005 07:46pm | #5
        Thanks, guys,
        The bathroom was the first place I ever tried it.  It is very possible that some of those things happened (e.g., thinset too dry, bubbles, etc.).  Thanks goodness it isn't happening in the family room!!!
        I really appreciate the recommendations on fixing it!  Many thanks!
        Dino - my best to Ryan.  I hope he's putting that cigar box to good use...  ;-)
          Dinosaur | Oct 01, 2005 04:15am | #6
          That cigar box has become his new special treasure chest. He keeps in it all the little souvenirs from each too-short visit we have together. 'Special' rocks he picks up; golf tees; a stick from a rock-candy lollipop; you name it.....
          Don't worry too much about fixing the tile over the Ditra; you'll figure it out once you tear into it, LOL. But I'm curious why you needed to lay Ditra under the bathroom floor tile. Usually we only use that for shower pans.
          Dinosaur
            Mongo | Oct 01, 2005 08:46am | #8
            He probably used it as an uncoupling membrane between tile and plywood.
            Dinosaur | Oct 01, 2005 01:44pm | #9
            Could be. But the Kerdi membrane is specifically designed for that, while Ditra is used more for it's waterproofing qualities.
            Dinosaur
            Mongo | Oct 01, 2005 05:02pm | #10
            I see it almost as the exact opposite, with Kerdi being more of just a waterproofing membrane for wet areas and Ditra being an uncoupler material that can also be a membrane.But I could be wrong. Wouldn't be the first time...<g>
          4. andybuildz | Oct 01, 2005 05:42pm | #11
            Mongo..thats exactly what I thought but I've been known to be wrong <G>.The secret of Zen in two words is, "Not always so"!
            Mongo | Oct 01, 2005 06:19pm | #12
            And to think people say we don't have a lot in common...<g>
          6. andybuildz | Oct 01, 2005 07:11pm | #13
            well we do share the
            Long Island Sound...LOLThe secret of Zen in two words is, "Not always so"!
          7. User avater
            Dinosaur | Oct 01, 2005 11:50pm | #15
            Ummmm, oops! (hee hee hee)
            Brain f a r t. Cervical dysfunction. Synaptic disconnect. Cerebral code calamity....
            (I meant what you said, not what I said.)
            I hate when that happens. Pardon I while me go rock under that crawl over there....
            Dinosaur
          8. User avater
            Crash | Oct 01, 2005 07:38pm | #14
            Dino,
            Mongo's right.  I used it for decoupling.  I had asked for advice in Breaktime and that's that was recommended by a lot of people.
      JeffBuck | Oct 01, 2005 06:37am | #7
      "it is unlikely that the floor flex has much to do with this."
      a floor can be framed solid ... no total deflection ..
      but still deflect between the joists. I know ditra says 3/4 is enough ...
      but it's not enough for me ... for this exact reason.
      floor flex can pop tiles over time. Little bit of vibration goes a long way.
           Buck Construction
       Artistry In Carpentry
           Pittsburgh Pa
      1. timkline | Oct 03, 2005 01:53am | #16
        agreed.  i think i made this statement based on the fact that he said nothing about cracking in the grout joints.  i have found that grout cracks are the first sign of flex, then tile pops.  if you just get tile pops, then i look to bonding issues.
