Shop Floor Using Green Treated Stringers
donshop | Posted in Construction Techniques on December 24, 2003 03:39am
Help!  I’ve completed a workshop and am about to install a wooden floor using 2×6 green treated stringers and screwed down 3/4 untreated plywood over a concrete floor with 2 inch foam under it.  All of the green treated around here is sold very wet.   Will I have trouble with warped stringers as they slowly dry or should I use untreated but dry 2×6’s instead?  I’ll appreciate all of your opinions.
  1. woodguy99 | Dec 24, 2003 09:26pm | #1
    Don, I would say that the 3/4" ply would keep the joists fairly straight.  3/4" Advantech, or 1 1/8" T+G ply, would be even better.  Blocking between the joists might help if you're really worried, but you might get squeaks later on.
      IMERC | Dec 24, 2003 10:02pm | #3
      Screws and PL400 should help with the squeaks.
      If the wood is that wet careful with the contact of yourself and the chemicals.
  2. mike4244 | Dec 24, 2003 10:00pm | #2
    You'll be fine, you may want to put subfloor adhesive on the joists unless you would have a reason to unscrew the sheets for access.
    mike
  3. gdavis62 | Dec 27, 2003 06:37am | #4
    Do you mean sleepers, i.e., the 2x6s are laying flat on the slab?  If so, why not save money and use 2x4s?
    Either way, if your 2xs are laying on the slab, as nailers for your ply, shoot 'em to the slab with Hilti pins and don't worry about movement.  Get that shop floor down and start making stuff!
  4. dIrishInMe | Dec 27, 2003 06:51am | #5
    Use green lumber in contact with concrete.  Don't let it dry out first as you will increase your waste to about 20%.  Sometimes that stuff will twist up pretty bad, but if you get it attached in place before it dries, the warpage, etc will be kept to a minimum.
    Matt
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
